#741
Thanks guys. I'll test clear coating the thermostat housing.
Has thanked: 1350 times
Been thanked: 232 times
#742
Yeah I think it looks good too. Just don't paint all the bolt heads blue. :troll:
#743
Installed:
#744
Dug this out of the parts bin:
#745
Cleaned it up:
#746
Looked at this:
#747
Cleaned it up:
#748
Still a little grey under there. I ran out of paint, but it's not bare metal under there.. and it's not visible. I'll leave it.
#749
#750
I cleared the parts with high temp clear. It toned them down a bit.
Has thanked: 430 times
Been thanked: 1295 times
#751
Now you have to paint the rest of the engine compartment, better get more paint. :lol:
#752
wayno » Sun Dec 27, 2015 12:31 am wrote:Now you have to paint the rest of the engine compartment, better get more paint. :lol:
lol.. some day. The rest of the bay is pretty clean actually. The frame rails could use some love.. but overall pretty good.
When the time comes and I get serious about paint, I'll strip it and paint it with something with hardener in it.
#753
Installed this:
#754
I just need to find some arm rests and I'll be good to go!
#755
I would consider the arm rests the easy part.. been looking for this door panel for almost 3 years.
#756
Could probably use another coat.. we'll see.
#757
draker » Sun Dec 27, 2015 9:29 pm wrote:I just need to find some arm rests and I'll be good to go!
Shouldn't be too tough. Just widen your search. I used some from a B210 that are close enough I can't tell the difference.
Progress looks great!
#758
Did the high temp clear need to be baked? If not, what kind did you use?
The clear I've been using won't cure.
#759
Taterhead » Mon Dec 28, 2015 9:13 am wrote:Did the high temp clear need to be baked? If not, what kind did you use?
I did use high temp clear. It cured fine. I'll grab a pic
#760
What I'm saying is did you have to bake it on? The stuff I used on some parts said it needed to be baked on but I don't have a way to do that and it's still kinda tacky/sticky after many months. If it doesn't cure out I'm taking it down to bare metal and redoing it.
