LZ23 engine build
Re: LZ23 engine build
#21
All I have here is a W53. No help to offer.
Has thanked: 430 times
Been thanked: 1295 times
#22
#23
Wouldn't you need a 720 L20B pan?
#24
flatcat19 wrote:Wouldn't you need a 720 L20B pan?
What I have in it is working, so I will measure it again and figure it out, I have quite a few oil pans around here, one of them will work, if not then I will use the one in there now, just won't be perdy. :lol:
#25
Oh yea, the ARP stud kit came today, Yea! :)
#26
Has thanked: 1350 times
Been thanked: 232 times
#27
Not sure if this will help you or not Wayne but this is a U67 head
This is a "210" head
#28
#29
I messed up and posted in the wrong thread, I will save this spot for my next post. :)
#30
#31
#32
#33
#34
By the way, this LZ23 engine is still sitting in the same exact spot it was a month ago. :lol:
#35
#36
#37
#38
Good point, hadn't thought about that.
