The Killer B
Re: The Killer B
finished sanding the other front rim. the back ones don't look to bad.
Aired up the front two, need to finish the rear two... Will do that tomorrow morning as I am putting them on the B
Re: The Killer B
woohoo!
Cant wait to see the end result Tim
Re: The Killer B
suspension hasn't settled in the front from swapping tires yet.. also found out my rear cylinder is leaking on the passenger side. I just bought two cylinders and replaced the driver side, this was on the list already. Guess it's happening sooner than later
Ill order up some shoes and spring kit, might as well do it all now that its saturated in brake fluid.
Anyways, here she is. Again, the front hasn't dropped yet as I haven't drove it... Just aired up the tires and getting ready to take it for a spin after i double check the lug tightness
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
Re: The Killer B
So how far did the front settle?
Re: The Killer B
taking a pic meow brb
Re: The Killer B
- Has thanked: 671 times
- Been thanked: 245 times
Re: The Killer B
hory chit !!
Those look GOOD !!! Izzo
Re: The Killer B
Thanks man!
They do look pretty badass... I'm getting some vibration when I drive. I double checked the lugs, they tight, shook the wheels, they on tight, air is correct PSI on all four, these are directional tires pointing in the right direction. I am thinking maybe they need balanced... I'm sure les schwab will rape me a bunch for balancing the wheels, mounting and dismounting... So just gonna rock them for now till i can find a spot to do it cheaper.
http://hpwizard.com/tire-calculator.html
165/55r14
165/55r14
Re: The Killer B
Oh yeah they are. Just gotta get the vibration thing figured out. Seems the worse of its around ten/fifteen up to forty or so. At around sixty its not as bad tho still there
Re: The Killer B
You got this.
Does it "shimmy" through the steering wheel ?
Re: The Killer B
Negative. I got it checked out. three were out of balance, one has a slight ding in the lip. leaves me with a little vibration at about 40mph, but only a little one... so good to go.
Re: The Killer B
THAT..is awesome news my friend ! ..izzo wrote:Negative. I got it checked out. three were out of balance, one has a slight ding in the lip. leaves me with a little vibration at about 40mph, but only a little one... so good to go.
a little vibration never hurt no one
I have a bent spacer on the front passengers of my yellow z that cause #$%# sometimes with a shimmy
The (3) of the tires were bald as @$@$ when I bought it ... it also had a flat-spot on the one that wasn't bald ..
lug-nuts weren't tightened down eveny (or at least close)
that was an interesting drive home + my stupidity = derp derp derp.
Re: The Killer B
- RedBanner
Re: The Killer B
When we getting like buttons?
Re: The Killer B
I cant figure out how to import it into this theme. Maybe jacob can
Re: The Killer B
Adjusted air feul mixtute since the air filter is gone. Replaced cylinders now just waiting for shoes and spring hardwarekit to sshow up and the rear brakes are complete and all new.
Re: The Killer B
Your new wheels sure look purdy on the b Tim
