RedBanner wrote:I only heard it scrapeing in and out of the drive way. Wich leads me to believe it could go lower.
i guess i could, but i only have 2 in to the ground from the engine crossmember..
where the frame swoops down in the front under the cab, ive got 2.5-2.7in to the ground.. thats just the frame rail.. the torsion bar crossmember hangs at about 2.2in from the ground..
i should get a picture of the speed bump at work. it has all the paint missing in the middle where it has a gap. i straddle the gap with the oil pan, and the rest of the undergarments drag.. lol
anyways, the next thing is the back leaf spring mounts. theyre only 2 in off the ground.. when i 3 link it, moar lowness will happen. ill prolly go down a touch more when i get the front suspension swap done..
i could just put a set of shorter tires on it.. like some 185 70s on my 14s would have this on its belly... id honestly like to have it on a set of 15x10s and some 215 55s on it..i wanna cut the fenders and put the flares on too..
