- Indy510
- Has thanked: 27 times
- Been thanked: 132 times
While changing the wiper cowl area, I chopped the front of the roof a 1/2" to get rid of the reverse rake roof line. I still hate the c-pillars, but that will get fixed later:
Then I took the body back off:
- Indy510
Below the doors is a 1.5x0.75" square tube rocker panel, which helped make the side of the car straight. Then I used an on-sale Eastwood dimple die set to make this filler piece:
- Indy510
The old trunk lid I made was never going to look right, so I traded some of my last Datsun parts for another trunk lid, with a poorly shaved lock hole:
- Indy510
These two pieces started out as a flat angle bend... then I shrunk them both ways until they fit the shape of the window frame:
More dimples... I should have used a smaller hole saw, but all I had was the 1-1/2" one I got for the roll cage:
- Been thanked: 1295 times
That is the most positive rep I ever gave anyone in my life, talk about customizing, you building a whole new car from scratch almost.
I might have messed up and hit what I thought was positive rep but it may have turned into negative rep, sorry I didn't mean to do that.
This car is still ridiculous and I still really, really like it. Your fab work has really improved over the years. Great work!
- Has thanked: 1350 times
- Been thanked: 232 times
- Indy510
Haha. Thanks everyone.
I cut off the c-pillars last month. They were never going to look 'right'. I think my mistake last time was not having all the body panels mocked up. So, this time everything is still on the Miata:
- Indy510
I basically finished both sides, but each pillar was 5 separate pieces of metal and had almost no patina left. So, I made a template off the best one:
- Indy510
The first two bends were easy on my super cheap folding brake, but the reverse bend was done clamped to a table -- using a soft hammer:
