So today I adjusted the box first, it is all in alignment now.
Then I decided to take it for a drive, I started it up and it was making noise, so I checked and it was the steering pump, I drove the 520 to the auto parts store and bought some and filled it up, then I started it and looked for leaks but could not find one, so I closed the hood and it was awful, the hood was rattling something fierce, I lifted it back up and it was hitting the turbo, I thought it was low enough but I guess it was not, so I cut the hood bracing off where it was hitting, I cleaned it up a little later and then took the photo below.
So I took it for a drive, the waste gate does not function but I took a piece of hose with me on case the boost got too high I needed the waste gate to function, I seen just over 10/12psi when putting my foot into the pedal getting on the freeway, and once on the freeway when I moved to the center lane to pass a truck, the EGTs ran around 800 degrees going down the freeway and got near 1200 degrees going up a short hill while keeping my speed going up that hill, it ran slightly hotter than I thought it would but I really cannot compare it to my 521 kingcab because the sender/sensor is after the turbo on that truck(wrong place) and this one is right at the exhaust manifold exit a foot or so before the turbo where it is supposed to be, I need to drive it a lot more to really understand it the way it is now.
My drive was only around 5 miles, during that drive I noticed that when I turned on the blinker the EGT gauge was jumping around, that is when I noticed it was not charging either, so after I got home and put it on the charger I started looking at the alternator, I checked all the connections and they were good, next I went to the fusible links and checked them and they were all good, the plug for the fusible links connected to the battery don't look that great but when I tested each wire they all had power so I plugged them back together the way they were before testing them.
I had started this truck several times while checking everything, since starting this turbo lowering conversion I had had too remove the injection pump control arm because the engine would not start as the injection pump controller would not move to the run position, but if it was not connected it started just fine and I had this choke cable connected to the arm that when I pull it the engine shuts down, I have had this issue with this truck off and on for several years, well after I checked everything I started it again checking the power steering pump again for leaks, I looked over at the DPC module, I had tested another one seeing if that was the reason it was not charging and there was no change, so I took the test one out and plugged the one mounted on the inner fender back in, I was looking at the engine while it was running and all of a sudden there was a pop like what happens when the glow plugs are finished warming up, I thought that was weird, I went around the truck and looked at the volt gauge and it was charging now, I git out my test meter and it was charging 13.5 volts, I took the charger off the battery and checked again and it was still charging, I shut the engine down, started it up again and after the pop it was charging again, so now I was real curious, I shut the engine down, connected the injection pump control arm to the injection pump again, got in the truck and hit the starter and it started just fine for the first time in quite a while, I turned the key off and it died, then I started it again and waited and when it popped the alternator started charging, now I have no idea why it is working again other than I did something, I suspect it has something to do with either the fusible links, the fusible link plug on the battery, or the DPC Module, but I do know this, the diesel wiring harness is weird, it's wired into the oil pressure, it appears to be wired into the alternator also for some reason, I just went out and started it and it was charging, I was hoping my radio would start working again but no such luck, that is a different issue, it works when it wants to and it doesn't want to right now.
After I drive it for a while I will figure out if it has more power, less power, or if it is still about the same using this turbo, also we have to keep in mind that this injection pump was modified to run richer, so that may play a part in the big picture also.
