my 77 kingcab
- Farmer Joe
- Farmer Joe
- Farmer Joe
- Farmer Joe
Re: my 77 kingcab
the z24 was short live fun..
it made some weird knocking noise that wasnt the bottom end..
that i got the KA at that point.
KLH620 KA24DE FS5W71B HF37
- Farmer Joe
- Farmer Joe
- Farmer Joe
Re: my 77 kingcab
built a trick carb adapter.. converted the intake to wet status with pluggin the injector holes with .40cal casings.
- Farmer Joe
- Farmer Joe
Re: my 77 kingcab
sorta rerouted the relays and wiring for them under the hood. got em away from the water slangin tire...
put the regulator on the core support along with the relays..
got rid of the shit fuel cell, and put a full circle system in ..
Re: my 77 kingcab
Exaust
- Farmer Joe
- jayden71
- Title: Bewb Captain
- Cars: '71 Viagra blue 521
Re: my 77 kingcab
Man, that poor L looks moar worn out than a cheap hooker at a sailors homecoming party.
Re: my 77 kingcab
Fixed... but you knew that huh lololjayden71 wrote:
Man, that poor L looks moar worn out than a cheap hooker at an i5 rest area.
- Farmer Joe
Re: my 77 kingcab
well, bee a bit since i updated..
been doing the daily driver thing with for the last few weeks.
havnt had any big troubles with it..
tryin to save up a bit of cash to get the new oil pump and timing chain set. i still have to get a st of rockers and shafts from the yard. i still need to get the 240 cam in it too. oh yeah, the IE too...
recent picture from the other day...
more to come here soon...
- Skeletonbonez
Re: my 77 kingcab
Build is nice dude. I was aways curious about raising the shock towers. makes me kinda miss my 620. Keep it up!
- Farmer Joe
Re: my 77 kingcab
few updates.
got the matchbox installed and working well. i also got a timing light on it.
dont know if EI helped or if setting the timing correct was the best thing ive done for it.. lol
anyways, its full time daily for it.. geting high 20s low 30s for mileage now. im diggin it.. more power, and better fuel economy! cake in mouth...
heres a video...
just waiting for the next pay period to get the timing kit and oil pump..
its time to get better brakes on this fucker here next. along with that comes a balljoint swap.
im gonna go with 83 and later 720 LCAs, spindles, brakes and prolly get a set of beebani arms..
already too much money wrapped up in those last two sentences..
more to come...
heres a video...
more to come...
Re: my 77 kingcab
I only heard it scrapeing in and out of the drive way. Wich leads me to believe it could go lower.
- Farmer Joe
Re: my 77 kingcab
i guess i could, but i only have 2 in to the ground from the engine crossmember..RedBanner wrote:I only heard it scrapeing in and out of the drive way. Wich leads me to believe it could go lower.
where the frame swoops down in the front under the cab, ive got 2.5-2.7in to the ground.. thats just the frame rail.. the torsion bar crossmember hangs at about 2.2in from the ground..
i should get a picture of the speed bump at work. it has all the paint missing in the middle where it has a gap. i straddle the gap with the oil pan, and the rest of the undergarments drag.. lol
anyways, the next thing is the back leaf spring mounts. theyre only 2 in off the ground.. when i 3 link it, moar lowness will happen. ill prolly go down a touch more when i get the front suspension swap done..
i could just put a set of shorter tires on it.. like some 185 70s on my 14s would have this on its belly... id honestly like to have it on a set of 15x10s and some 215 55s on it..i wanna cut the fenders and put the flares on too..
