the mine now coupe.
Re: the mine now coupe.
Looks like I need a set of needles, size m83 or just run this a14 rich as hell mid and top end.
Modified a modified z car airbox I made for a single weber 45, now remodded for duel sus
Got about 4 passes around with my spot welds, probably take 8 more. Sheesh.
Bout an inch more clearence than my dome filters at the carb bore.
Looks kinds cool, will go clear up to the core support too, and filters are only 4$
Still less than my dome filters well past the master.
- Cars: 1200 coupe
Thanks.
I Rikey too man! Cool mod for shiz
- Eagle_Adam
Bueno!!!!!!
Can't wait to see this one running!
- Eagle_Adam
Dbl post fail
So, besides the fuelpump, ive done everything I can, time to pull the 12 and make some mounts.
I stabbed the trans, for those of you that dont know there are 6 long bolts in just the top half of the bellhousing, ive ran em wit 2 before tho. Not this time
Rebushinged the shift, the stock plastic ones where gone, used ford door hinge bushings tho.
Now there Brass.
Also I had to go to 4 places to find a 1/4" t for my fuel lines. Then I didnt like how it looked, so I modified another stock datsun peice to fit. Might reconize it. One more peice out of the emissions delete scrap pile! Actualy its more like the "I just installed a 32/36 scrap pile, but whatever, you can see my thermostat housing to a kit at one time in this pic too, flat sided.
It has a restricted side to regulate the return pressure, so I cut that off and gently straightend it out.
Not the prettiest but I like it alot more than the rubber hose and t.
I think if I had some sort of roller to straighten it out gently I would be completly satisfied, but ill probably never change it if it works lol, double flaired both ends so it seals well.
Aslo found out the ei dizzy I had with this motor is pretty loose, but the 1200 already has ei so I have that one.
Mounted my 80 210 ir alt as well.
And finished welding my airbox.
But now its baxk to bed, cause I work at 7, so I leave at 530 pm. Long night tonight so maybe nothing tomarow
Now there Brass.
As comparison, heres the fuel line with the t.
Versus the stock fuel/fuel return line cut and bent.
Banner, I bought a NOS twin fuel line from Z therapy for $25 at Canby 2013. I can grab you the part # if you would like.
Mike
Mike
Thanks man, id like to have that around,
Im pushing the 1200 into the shop right now to drain the fluids and start pulling it apart.
But I just worked 16 hours with a 2hour round trip, and another tomaro, so I dont know how far I will get, beet tired, and I stop when I start making mistakes, wich was about 3 hours ago, lol
Got all the wires and hoses disconnected, have to.do.for now, gotta go to work in 4 hours
Also, as Driven suggested I got soke z seat, pretty great condition, should cleean up great!
Oops I.see I fergot the alt wires.
Is it in yet?
^^Hehe^^
Woodburn. Remodeling the woodburn outlet malls
KEWL I painted all the signage at that mall 15-20 yrs ago. Imagine that big monument, in its parts. inside an automotive paint booth.RedBanner » Tue Jul 08, 2014 7:25 am wrote:Woodburn. Remodeling the woodburn outlet malls
