soon to be LZ2.3 521 :)
Re: soon to be LZ2.3 521 :)
#741
uberkevin » Tue Jul 08, 2014 12:55 pm wrote:Change front cases.
Trip myself down some stairs.
:rofl: :rofl: :rofl: :rofl:
uberkevin
#742
Post by uberkevin »
Maybe a work place accident...
Nah.
Getting shit together to put the Lz in, also gotta make sure the drive line will work. So measure measure... oh!! What u joints do I need to get?
#743
which ever ones fit, but not the ones from autozone. they fail.
uberkevin
#744
Post by uberkevin »
uberkevin
#745
Post by uberkevin »
uberkevin
#746
Post by uberkevin »
All in all it wasn't very hard.
Wayno I'd like to thank you, without your ratsun thread I wouldn't have been able to do this. So thanks for being an awesome datsun owner. :)
#747
uberkevin » Wed Jul 09, 2014 9:25 pm wrote:Image
Your Welcome, as you said though, it's not very hard to do.
I am like a meth addict, I like taking things apart, but unlike a meth addict, I like putting them back together also, I heard that this transmission conversion was possible, then I heard it again from a completely different source, about that time I had just destroyed my fourth dogleg 5 speed in 5 years in the work truck, so I gathered what I needed and gave it a shot, and it was the best thing I had done for the work truck since the L20b upgrade, and when someone like me figures out something awesome, I want to tell everyone.
I am at 6 transmissions to date in the work truck, 4 doglegs, and 2 hybrids, the only reason I replaced the 5th one was because it would pop out of 1st under compression, and the second gear syncro was shot from slamming it into 2nd gear when going up hills, number 6 is still going strong.
BTW, the same article is in the "how to" section here also, BLUE also wrote an article.
#748
I need that shifter return spring.
Lol.
Are you documenting this swap?
uberkevin
#749
Post by uberkevin »
The only thing I noticed was if I wrench down all the way on the inside bearing cover bolts I was unable to spin the trans.
I
uberkevin
#750
Post by uberkevin »
The plate is on tho.
uberkevin
#751
Post by uberkevin »
You can have what ever you need from that thing flatcat.
#752
Return spring and the ball that's in there.
uberkevin
#753
Post by uberkevin »
And documenting? How isn't this 38 page thread a big document ha
#754
uberkevin » Wed Jul 09, 2014 10:06 pm wrote:The only thing I noticed was if I wrench down all the way on the inside bearing cover bolts I was unable to spin the trans.
I
Something is wrong then, that cover has to be tight so no gear oil will leak out.
uberkevin
#755
Post by uberkevin »
Maybe the bearing isn't all the way down.. The one I had to change.
uberkevin
#756
Post by uberkevin »
First I forgot to put the washer thing in the cover for that bearing. Had to take it off the plate and put that in there. Ha.
I'll double check everything tomorrow.
uberkevin
#757
Post by uberkevin »
I guess I should be clear.
Wayno I didn't do the exact same thing as you..
I used the Z series short 720 trans and a 620 4 speed front case along with the 4 speed lower bearing oh and the bearing plate is from the 4 speed.
uberkevin
#758
Post by uberkevin »
Like I thought I didn't put the lower bearing on all the way.
Spins free with everything snug.
Also dropped the one piece off at a shop to replace u joints and make sure it's sound to drop into a truck.
May be around 100 bucks. Not bad.
#759
uberkevin » Thu Jul 10, 2014 3:06 pm wrote:I guess I should be clear.
I have always wondered if this would work, I was lead to believe that one of the shifter rods was a different size and the case would have to be drilled, did you have to drill anything?
uberkevin
#760
Post by uberkevin »
No sir. Everything went on the shorty trans like it came off. Easy. Didn't force anything. I was also wondering about them when I took it apart. I said fuck it I might as well try.
Glad I did, fuck now I've got a 5 speed and a lz waiting to be put in. Drive line may be a week from now.
For some reason stores don't have brass core plugs either wth
So I'm waiting on those as well.
