Ok I had some fun with building this transmission. Had to tear apart the CA transmission as well to get the 3rd/4th synchro hub pressed off.
Pressed it onto the transmission I am building (KA one) and I quickly realize it is way bigger than the 3rd gear synchro... damnit.
So I use the CA 3rd and 4th gears. And I got lucky. The CA transmission used the same 3 piece synchro for 2nd and 3rd, and just used the 1st gear synchro on 4th as well. Well I had ordered an OEM 2nd gear synchro and my kit came with one as well. Whew.
So I used the kits 3 piece on the 3rd, and the new OEM on 2nd. I ended up reusing the 4th synchro from the CA transmission as I could hardly perceive any wear.
New bigger synchro hub means a bigger coupling sleeve (couples hub with gear). And then I noticed the 3rd/4th shift fork from the CA transmission was steel and not aluminum...cool.
I basically use anything from the KA transmission that I could as it was in better shape. But I essentially built a Japanese spec CA transmission with a taller 5th gear.
View from Driver side:
View from Passenger side:
