After removing the sheet metal
To the rack.
With hood on, the 3.75" it was bent to the right really shows up.
Dave and I destroyed the already bent left front tension rod bracket in pulling the front end back.
Front and rear as close as we could get them on the frame rack.
Floor and trans tunnel floors patched in from Driven.s coupe.
Still need ground down.
Pulled the gas tank, looks good from the top.
Bottom side not so good-stock tank only holds about 10 gallons to began with-this would be a bit less.
Was getting ready to weld in frame connectors and pulled the back seat bottom?
They needed a way in and out.
Frame connectors and plates-1X2-.120 wall and 3X4 plates. Having them welded in by a friend with a 4 post lift.
Under the decal, on the doors were holes and lots of rust. So had a couple to doors laying around..
