Located: Portland,OR
I have the following 1980 z20e 200sx hatchback EFI parts as a package or separate if enough to make it worth it.
It looks to be there is less than 60K on all of the parts listed below (all from the same car)
*1980 200sx hatchback z20e intake manifold with all injectors + whatever is on the manifold (nothing should be taken off to my memory).
*1980 200sx z20e ECM (computer)
*1980 200sx z20e AFM (air flow meter)
*1980 200sx z20e engine harness attached to intake manifold ( the one that goes to the computer-to-engine ).
*1980 200sx z20e fuel pump
*1980 200sx z20e fuel injector resistor
*1979 280zx Intake manifold
*1979 280zx throttle body
and not included in the package , but seperate I also have the
*1980 200sx z20e EFI fuel tank
004 by 71240z, on Flickr
008 by 71240z, on Flickr
007 by 71240z, on Flickr
006 by 71240z, on Flickr
002 by 71240z, on Flickr
001 by 71240z, on Flickr
NOTE: Now looking in the pictures it appears the engine harness is cut where the IGN , AFM , and Injector resistor wires lead to. the AFM pigtail is on the AFM itself as I write this , but the others I don't believe are. Wiring diagrams and manuals are available online should be straight forward fix.
Price = $160
Keep in contact with whats going on if buying
Thank you for doing so in advance !!!
email for questions .. happy to answer if I know it !
Advertiser Info
I'm BLUE
*Sold*- 200sx EFI z20e conversion parts
- Has thanked: 669 times
- Been thanked: 243 times
Re: *Sold*- 200sx EFI z20e conversion parts
SOLD.
