Adam's annoying ass green 620
- Converted_to_datsun
Hmm, I'll have to try to fit my wheels on a hardbody sometime to see if it'd work. They're 0 offset slotted mags
flatcat19 wrote:The stock Hardbody rims are offset around the calipers to fit them.
Dual piston HB clappers won't fit most 14" wheels. And some 15s don't work either.
Offset is key.
Aha! There's the nitty gritty. That's why they fit. thread jack ftw
you get everyone to join the band wagon and do a thumbs down bahhahaha jk
- Eagle_Adam
encourage...... i dont need no stinkn encouragement.....
wait a min.....
ok i might need some encouragement
wait a min.....
- Eagle_Adam
Just got word my mounts just shipped
sweet sauce boss! When's the plan for the swap?
- Eagle_Adam
Once all the pieces are here, ill finish the weber swap on my truck so I can pass DEQ(I traded my SU's for some parts)
Then once I have tags it's game on! I've got 6 or 7 weeks left to finish the swap so I'm still on target!
Why mess with the Weber swap? KA should pass DEQ without any issues. Probably without a cat too.
I was thinking the same thing.DRIVEN wrote: KA should pass DEQ without any issues. Probably without a cat too.
My cousin knows a guy who swapped in a mk3 VR6 into a 88 Jetta. The VR6 was cleaner at the tail pipe without a cat than the stock 8valve was with a cat.
- Eagle_Adam
Piece of mind more than anything......
But at this point ill probably say fuck it
- Eagle_Adam
- RedBanner
- Title: MasterBlaster
- Has thanked: 2 times
- Been thanked: 2 times
The walboros, and holleys ar both loud, but if mounted correctly you can cut out the vibrations and it quites them down a whole lot.
- Eagle_Adam
I think I'm honestly just gunna use a JY pump..... $25 and i get the mounting brackets too, then if it goes out i can get a brand new one from the stealership
Wednesday marks the "start" of my KA swap!
why?
cus Wednesday my dad goes in for his hip replacement surgery, he will be down and out for 6 weeks minimum
why?
- datsunmike
All the master cylinders on the road are used.flatcat19 wrote:I have never understood why people want to use a used master cylinder.
It's the heart of your braking system.
Maybe I've just seen too many bad things.
It just scares me. I'm a wimp that way, I guess.
Hope you find one!
- Eagle_Adam
- Eagle_Adam
its like freek X-mas today!!!!
got my Redeye mounts in the mail today!!!!!!!!!
just gotta slot the trans crosmember when i pull the Lmotor out and im ready for a test fit!!!!!!
- Eagle_Adam
i cant wait for you to post pics of that one thing.........
