Adam's annoying ass green 620
#201
I know... soon. So very soon.
Sometimes I am indecisive, so instead of problem solving it, I play games. I should have it wrinkled out today. Final assemble tomorrow or thursday or whenever I get the parts...
Eagle_Adam
#202
Post by Eagle_Adam »
no rush man, its a ways out still. Just anxious.............
#203
Well I just ordered the remaining parts from MCMaster Carr.
And because its fun to post pictards, and not a whole lot of people check your thread here...
Eagle_Adam
#204
never noticed your name on it before!!!! branding for the win!!!!!!!!!!!!
#205
Nice seat you had for sale there.
I got a sneak peak at a down the road pic of said board. I could fuck it. omnomnom
Eagle_Adam
#206
Well, my pops had his hip replacement surgery yesterday, so its game on boys n girls!
picked up one of my KA24DE's from storage along with the 5 speed i got with it
picked up a new clutch too
motor and trans are split
motors on the stand
started pulling things i dont need
fan clutch
EGR
emissions BS
old motor mounts
ended the night with giving the motor a bath in 2 cans of break clean then pulled the cam cover to see what i was working with
#207
Fawk yeah man!
This is gonna be cool when you're done man
Has thanked: 1354 times
Been thanked: 236 times
#208
Awesomeness. That's what you're workin with.
Eagle_Adam
#209
part of me really just wants to clean this motor up and run it as is.........
the timing chain looks great, cams look good, ran when pulled, just dirty with a leaking front cover.....
but then part of me is reminding myself of how easy it "should" be to tear it apart
#210
I would rebuild it. You never know how hard it was ran before.
Another thing, IDK about those motors. but the cams look a little dirty, like it didn't get oil changes.
Eagle_Adam
#211
ive been looking at build threads and pics for a few weeks now and it seems to be a 50/50 split between what the heads look like
some are perfect and new(fresh outta the machine shop) and the other look like mine(used)
so im not sure of what to make of it. Toying with the idea of sending it to my machine shop for a good cleaning and freshness
#212
I'd just do a leakdown with it on the stand. Pull the oil pan and measure bearing clearances.. if those are all good.. run that bitch.
Eagle_Adam
#213
may sound newbish...
but ive never done a leak down test b4
#214
There isn't much to it. Just as easy as a compression test.. except air comes from an air compressor.
Basically, you put the piston at TDC one by one. Apply compressed air through the spark plug hole with a leakdown tester. It has two gauges. One tells you how much are is applied, one tells you how much is leaking. You just determine how much air is leaking and from where. That should tell you about the engine health. Use that along with the bearing clearances and it will tell you what you want to know.
#215
And you don't need a shit ton of air either so a small compressor works just fine.
Eagle_Adam
#216
i has no compressor.......... sad i know
Eagle_Adam
#217
#218
So, when does the L20 come out?
Eagle_Adam
#219
once the A motor goes in the B.....
which should be tonight, i hope
#220
and then?
