the mine now coupe.
Has thanked: 1350 times
Been thanked: 232 times
Re: the mine now coupe.
#421
Maybe check this place if you haven't.
Before you grind your shaft, hehe.
http://www.motionindustries.com/motion3 ... /browse/en
RedBanner
Title: MasterBlaster
Has thanked: 2 times
Been thanked: 2 times
#422
Post by RedBanner »
So I bent up my clutxhline... really start to have high anxiety any time I double flare something, so I took the scenic route so it would have both flared ends intacted lol
On many datsuns this is bolted on and I can just move it. But not a 1200 they weld that shits on, so I made another one, would have been a million times easyier to screw it on before I dropped the motor in..
Also found a box full of centercaps for 20$, win!
Just sandblasted and painted a bunch of stuff, waiting fot it to dry, and assemble.
RedBanner
#423
Post by RedBanner »
Axles are in, brakes are in, ebrake fixed, cutch line installed, drums... drying, if I had an exaust flange I could make it to the gut tomarow. But alas, I dont.
Gotta install my valve cover, bleed the brakes, and re wrapp my altenator harness.
Engine needs oil, rad needs coolent. And its dont. Oh yeah trim alittle for the shifter, and install z seats. Then its done.
#424
Eagle_Adam
#425
Post by Eagle_Adam »
Well now u have the exhaust parts you need and a unisync soooooooo.....
Updates yo?
RedBanner
#426
Post by RedBanner »
Just got home... sat on i5 after delta park for 2 hours and the subi doesnt charge under 2k.... fuckin sucked. Safety meeting then exaust. Might get to the recomended carb checks even...
RedBanner
#427
Post by RedBanner »
RedBanner
#428
Post by RedBanner »
Lol copy and past. Im a grown man!
Eagle_Adam
#429
I know ur up......
Get to cruzing status yet yo?......
RedBanner
#430
Post by RedBanner »
No, I just peiced exaust together out of peices that sould have been thrown away.... and fixed my harness, installed valve cover, cleaned rear drums again... need some brake clean, and brake fluid. Havnt taken the carbs apart like you wanted me too, havnt trimmed shifter hole. Fuckit im so tired. Going to bed.
RedBanner
#431
Post by RedBanner »
Holy shit, been fighting it all day, not even to the point of turnin it over, got one brake hangin up bad. Tryin to bleed em solo aint workin even with the vacuum bleeder. Had to remove the radiator 6 fucking times cause im a space case. Down to a few thinhs, again.... , clean the front carb (thing1),
tidy a few connections,
Intsall the good starter,
throw the bad starter away so I dont install it again before I see that the posts are all busted.
Install hood battery and dizzy oring (that is on my bench after I timed the dizzy and bolted it all in,
2 hose clamps,
And figure out this rear passenger drum issue.
Wich will most likely take a sexond person.
Bolt on rear wheels.
Drive.
Didnt cruise the gut today, but might be zippin around tomarow!
#432
RedBanner » Sat Jul 19, 2014 10:04 pm wrote:Holy shit, been fighting it all day, not even to the point of turnin it over, got one brake hangin up bad. Tryin to bleed em solo aint workin even with the vacuum bleeder. Had to remove the radiator 6 fucking times cause im a space case. Down to a few thinhs, again.... , clean the front carb (thing1),
2 hose clamps,
Drive.
Buy 12' - 15' feet of clear tubing from the hardware store and feed it back to the reservoir. That's the only thing I could bleed brakes on the dime with only one person. Worked well.. and cheap. I think I paid $3.
RedBanner
#433
Post by RedBanner »
Annnddd....
Still not done.
#434
2 hose clamps,
Drive.
Or into a 2 liter bottle so you dont put old brake fluid back into the circuit... Thats the method I preach though.
#435
2 hose clamps,
Drive.
Good point.. mine had all new fluid.
RedBanner
#436
Post by RedBanner »
Fired it up, ran a few, losse dizzy turned when I reved it, took gas to the face, loading video now, anyone wanna see first start up?. Taking a break and then I will mess with the passenger drum
RedBanner
#437
Post by RedBanner »
First try.
#438
Not Adam's first facial?
RedBanner
#439
Post by RedBanner »
Not adams last facial....
RedBanner
#440
Post by RedBanner »
