soon to be LZ2.3 521 :)
uberkevin
Re: soon to be LZ2.3 521 :)
#821
Post by uberkevin »
I'll clean the shit out of it.. gotta get the wheels moving soon. Going to pressure wash the hell out of the truck tomorrow before I put stuff in.
uberkevin
#822
Post by uberkevin »
uberkevin
#823
Post by uberkevin »
Got the oil pan off the l20b and pick up.
Oh so the z22 dip stick is on the ddriver side of the block.
Do I use the z22 tube still? With the l20b dipstick?
The dipstick is higher up on the z22 than the l20b as well.
#824
No...
Look at your Z22 block again. I should have a spot in the same location as the L20b block does for a dipstick. Drill that. Put dipstick there. Use L20b tube and stick, as you are using the L20b pan.
uberkevin
#825
Post by uberkevin »
I'm using 521 oil pan and pickup.
But okay thank you.
uberkevin
#826
Post by uberkevin »
So I'm about to set my ring gap.
I'm following the "how to modify your datsun"
It says the gap should be set About 0.004"  times the bore in inches. So doing the math the top ring gap should be set at about 0.014. The book also says the second gap should be set 0.002 less then the top ring, do to it being cooler. This means i set the second ring gap to 0.012 right?
uberkevin
#827
Post by uberkevin »
89mm head gasket from datsunpartsllc.com came today!
Now brass freeze plugs and I'll be putting the block in.
The NPR piston rings are gapped to big.. The second ring is at 0.020.. wtf... All of them. Number one was pretty set at 14 thous, Well three of them were 14 the last one was 17 thous... I don't get it.. fucking says quality guaranteed on the box...
#828
uberkevin » Mon Jul 28, 2014 7:31 pm wrote:I don't get it.. fucking says quality guaranteed on the box...
uberkevin
#829
Post by uberkevin »
Ha!
#830
Call Nissan and see if you can get a set of OE standard bore rings for the KA-E.
#831
Good thing single KA-E piston rings are .011-.017 top and .017-.024 second...
uberkevin
#832
Post by uberkevin »
Laecaon, thank you .. I don't like dealing with tiny numbers. I guess I knew where to set the ring gap but not really the lowest it could be.. seemed 14 for the top was pretty clear so when I putt them in the bore and they were already 14 I was stoked.
The book says the second ring should be 2 thous less then the top.. I've seen a few things say the middle needs to be around 17.. wouldn't that make the second ring .012?
uberkevin
#833
Post by uberkevin »
Found what I needed to find on a pdf from NPR site...
"NPR manufacturers each piston ring gap with the correct OEM specification for each individual engine. There is no need, nor do we recommend that you alter them in anyway as this might void our warranty. Also note these end gaps are set at exact bore dimensions"
Lots of reading to find that. Even tho I figured such I really didn't want to take any chances. Ha. I'll put these fucks in now that my mind isn't being dumb and over thinking shit.
#834
On my engine I only filed 2 rings of the eight. Rest were spot on.
uberkevin
#835
Post by uberkevin »
So the datsunpartsllc 89mm head gasket does not fit to my liking.
#836
Yea, Al is the owner of DatsunPartsLLC... he will say anything to move a product...
whats not to your liking?
uberkevin
#837
Post by uberkevin »
He had said he's used this gasket on an lz2.3 build... don't know how those blocks turned out down the road but the gasket laps into the bore no matter how straight I make it.
If I get one or two cylinders aligned ehh, kinda to my liking it still laps into the bore on the edges because it's oval makes things... stupid.. ha. The other cylinders it also laps into the bore just a little more then the other two..
I'll upload some pictures.
uberkevin
#838
Post by uberkevin »
uberkevin
#839
Post by uberkevin »
jayden71
Title: Bewb Captain
Cars: '71 Viagra blue 521
'79 Patina KC 620
#840
Post by jayden71 »
MMMMMMM...engine porn!!
