Country slice
Re: Country slice
#121
Yes ! 100% agreed ! None of this BS cooling fan modules or alternator clutch pulleys designed to extend the life of a $12-$15 belt.
Yet another scam/Garbage
Re: Country slice
#122
Nobody gives a fling post update. New aisin water pump/thermostat into wifes daily. Probably wont be touching these recent replaced parts again.
Re: Country slice
#123
Not much of anything , just a repair. Typical home stuff.
Noticed some bubbling of water/air between an expansion joint. Looked at the valves/pipes next go the home. Those weren’t it.
Re: Country slice
#124
Got a tool or two delivered
Result ? Apparently this joint was the culprit. Got lucky.
The tool worked pretty decently especially considering doing aggregate. The 3.5 gallon (small) water pressure bottle for the wet cut D blade saved the day.
The existing compression coupler ? Yeah...literally tightened up the nuts , and it stopped leaking. Ordered more parts (locally didn't have anything).
Re: Country slice
#125
Definitely could have been worse.
Re: Country slice
#126
110% luck of placement , and type of leak. Feeling fortunate
Has thanked: 1354 times
Been thanked: 236 times
Re: Country slice
#127
So lucky!! Good job getting it fixed
Re: Country slice
#128
Thanks Tater ! (sorry for very very late reply)
Re: Country slice
#129
So.... little things.
We've been making this place our own.
Filled probably 40-green recycle bins of debris from trimmed trees etc...so far over the last few months.
Took down some more trees/bushes.
Painted 75% of the place (I've just been super busy with work/family balance)
and more.... will have to take pics later.
I have a large (to me) tree I will have to rent a lift for to trim back properly.
more to come
Re: Country slice
#130
Would it be cheaper to have a tree guy come and trim the large tree than to rent a lift?
