I used my chainsaws today, the chains were not sharp on either of them, so once the 24" ran out of fuel I used the 32" until it ran out of fuel, then I put the brand new chain on it and it went thru a 32" log almost like butter, its not a race chainsaw but one has dreams when a new chain is installed, there is one more load left and I believe that is all there was to be had unless the cousin drags some more logs in from somewhere I do not know about.
Here is the load today, I did not really fill it up as mentioned as there is only one load left.
This area was for parking my small tractor, but I needed somewhere to put the Fir firewood pile, except for about 10 large rounds it all fit in this area, here is where I was this morning.
And here is it almost completely full, I do not know exactly how much firewood is in this area, I suspect it is close to 6 cord.
The maybe 10 rounds left are all 32" or larger, so far I only have had one piece of wood drop not very hard on my right foot where them bone on bone joints are, it hurt like hell but it appears to have not made the foot worse(happened a couple weeks ago), so I guess I am lucky, I have a couple years of firewood stored now.
The other day I was sitting in my living room doing something other than watching the TV although it was on, I had put some wood in the stove and left the door cracked open to give it air and get it burning good, I heard this howl, it started getting louder, I realized that I had a chimney fire starting/already going, I closed the wood stove door to cut off the air and went outside and the cap/screen was on fire, now I had already had to clean that cap because it had plugged up less than a week before, but one can only get it so clean, so I went onto the roof to check the wood structure and see how hot it was, it was not so hot to worry me so I went into the attic and checked the tube, it was warm also but not so much to worry me, I checked the roof wood again and it had cooled and the chimney fire was out, I went into the attic again and the tube was cooler also, right then I heard a knock on the front door and I called out I would be right there, I opened the front door and the fire dept was there, I told them I had a small chimney fire and it was out, they smiled at me and left as there was no visible fire, I believe my new neighbor that hates my wood stove called them, I got on the roof one more time and looked at the chimney cap, it burned everything squeaky clean, there is zero creosote left, I will look at it/watch it more often now, this wood I am burning now, or at least some of it come from blown down trees last winter, maybe this is why I had creosote build up, the wood I am bring home now is 2+ year old seasoned wood, I should not have as bad of creosote issues with it, maybe I should burn this stuff now or at least try it.
