Anyone have a complete rear axle to donate to the cause? (I'm effin broke)
It will be going on a 1980 720. IDK what gears I have now. Rear end sounds good, but there is a slight wobble. I have had the drums turned, new shoes, one new cylinder. Seemed to calm it down a bit but didn't eliminate it. Thinking either the drums are warped somehow or the axle may be bent?? IDK. It's been like that for 8 years now....
Anyone. If someone has one they don't mind hooking me up with that would be tits. I can give you mine if you were after the third member? I'll try and see what ratio it is if anyone actually can hook me up.
Rear axle/Complete needed
- Eagle_Adam
Re: Rear axle/Complete needed
ive got one we can work out
complete drum to drum
Charlie69 wrote:Could be bent wheel or bad leaf spring bushings.
I think its the drums possibly. I can feel it when i hit the brakes, too. The wheels have been changed 3 times since i've owned it. With a drum being bad that long I bet the bearing is probably no good. but it doesn't leak fluid. IDK what it is for sure.
When ever I have a pulsing brake pedal, it seems to always be something stuck on the front rotor on one side or the other, it happens to me because the truck sits to much I think, it's happened more than once, but it drives smooth, just an issue when I hit the brakes.
wayno wrote:When ever I have a pulsing brake pedal, it seems to always be something stuck on the front rotor on one side or the other, it happens to me because the truck sits to much I think, it's happened more than once, but it drives smooth, just an issue when I hit the brakes.
New pads, new rotors, new wheel bearings up front. I don't think its the fronts.
Hey bro, if the one with Adam doesn't work out, I still have that spare rearend that I got with the 4x4 you sold me.
