How to install an early 620 sway bar on a ball joint 620
Forum rules
Converted_to_datsun
Post by Converted_to_datsun »
How to install an early 620 sway bar on a ball joint 620.
Basically not too complicated, the camper version actually came with a sway bar so all of the ball joint 620's already have all the mounting locations. For some reason they were no longer stock, a camper one should be a direct bolt on.
But if you can't find a camper one, a sway bar from an early 620 is almost a direct bolt on. The only real mod needed is a longer sway bar end link you can buy right off the shelf at the auto parts store. I got the longest one they had on stock which was an energy suspension 4 5/8"-5 1/8" which is barely enough to clear the tie rods. I'd actually recommend the 5 1/4"- 5 3/4" just to be safe. After I installed my new sway bar I felt a huge improvement in cornering, it's completely worth the effort.
Sway bar
Installed!
Re: How to install an early 620 sway bar on a ball joint 620
Ball joint 620's don't have sway bars stock?
That's odd.
When I scrapped the 620 in my yard that is one of the few parts I kept.
Converted_to_datsun
Yea lol seems weird they stopped putting them on stock. At least all the mounting holes are on the frame tho
Good call on saving the sway bar!
Always thought I could find a way to use it somewhere.
I hope I still have it. Made a scrap run a few weeks ago.
Yikes.
datsunmike
Post by datsunmike »
Converted_to_datsun
Pretty much what I've found from a little research. I tried the original bolts for the sway bar ends and it hit the tie rods horribly. I was able to find longer ones on the shelf at the auto parts store that worked perfectly. They were right there in the isle by aftermarket tacks and stuff. I also got polyurethane bushings which probably helps as well.
I just went out and made sure I had the sway bar!
:fyea:
FOUND IT!!!
Eagle_Adam
Post by Eagle_Adam »
i just did end links on my 78
i have a sway bar :P
im thinking yours was taken out
Converted_to_datsun
Naw dude, there's tons of later trucks without them.
Eagle_Adam
#10
guess im a lucky mofo
Converted_to_datsun
#11
Haha probably, you also had te Delux trim package right?
Eagle_Adam
#12
not on this truck
