Basically not too complicated, the camper version actually came with a sway bar so all of the ball joint 620's already have all the mounting locations. For some reason they were no longer stock, a camper one should be a direct bolt on.
But if you can't find a camper one, a sway bar from an early 620 is almost a direct bolt on. The only real mod needed is a longer sway bar end link you can buy right off the shelf at the auto parts store. I got the longest one they had on stock which was an energy suspension 4 5/8"-5 1/8" which is barely enough to clear the tie rods. I'd actually recommend the 5 1/4"- 5 3/4" just to be safe. After I installed my new sway bar I felt a huge improvement in cornering, it's completely worth the effort.
Sway bar
Installed!
